2006 Pacifica idle jumping hard Not running
Ok. So I went in to check for an oil drip. Tool plenum off and everything else (just like I'm going to do a valve cover gasket replacement). No leaks.
Put all back together. All plugs and sensors as well as hoses are back in place. Nothing is crossed up. All screws lined up. All hoses are in correct position and clamped (when necessary).
Went to start car all it does is rev up and down. Hitting gas does nothing. Checked MAP it's plugged in. All hoses are plugged in see no cracks. Code P0068 (duh) but can't seem to figure out why.
Double and triple checked everything. Unscrewed all 3 front plugs to look for oil but put all back in place. Did not cross any plugs they are in the right place.
Was checking for oil drip due to horrid smell inside cabin every 10 min or so after driving. Exhaust system has no leaks. Had cat muffler and resonator replaced anyway. So I was checking for a slow oil drip hitting something hot
Any ideas why car is doing this now? Did my map sensor go bad somehow during this? I don't have a voltmeter.
On the tube there was no gasket which I thought was odd. But never had an issue. Is it possible it fell off into the manifold when I took the tube out?
There's def an air leak there.
almangar
Sep 22, 2012 06:59 AM
