2006 Pacifica remoter start problems
Old Aug 21, 2011 | 04:42 PM
ttype's Avatar
Default 2006 Pacifica remoter start problems
Hi Guys,
I am new to this board. I went to the dealer and gave them my VIN# and they provided me with the 2 part system for the remote start. I hooked up everything as they said and went through the programming sequence. I got both remotes activated, and also did the tach programming successfully. Problem is the SKREEM transponder interface programming. I put in the 1st key, turned it on the on position for approx 5 sec, turned it to the off position and removed the key and put it on the passenger seat. 5 sec later I put in the 2nd key, turned it to the on position, waited 10sec for the single chime and the anti theft light to start flahing. I turned it off, took the key out and put it on the passenger seat and pressed and released the programming button on the main harness. 30sec later I pressed the remote button twice and nothing happens.
I have checked, doubled checked and triple checked my wiring and everything is as instructed. How come it won't start?
One thing I did do when installing the unit was I removed the brake lamp switch and pulled the harness downward so I could splice into that wire easier. Realized afterwards that that is a no no. But if that was a problem would I not also have a problem doing the Tach rate programming??? My brake lights all still work fine......... Please help. Majorly frustrated right now.
Old Aug 21, 2011 | 08:26 PM
busboy4's Avatar
I have not installed mine yet but....I know you saw this:
Caution: Do not remove the
brake lamp switch from the
mounting bracket. If the switch
is removed from the mounting
bracket, it MUST be replaced
with a new switch
I'm not sure what happens to the switch when you remove it, but it does say "must". I would certainly start there. I am guessing the starter is receiving a "brake on" signal and therefore will not start. Again just guessing. I realize you had to cycle the brake during the tach learn so it is somewhat of a long shot. One other thing. During skreem programming it says to keep the fob's at least 2 feet from the ignition. Why not try the process again, perhaps with an assistant at say 5-6 feet?
Good luck with it. Let us know what you learn.
Old Aug 24, 2011 | 04:20 PM
ttype's Avatar
I replaced the brake lamp switch and went through the procedures again. No dice......
I called the 1800 number on the instructions after struggling through this for countless hours. They told me to go inside the black SKREEM box and cut the purple and orange wires and tape them off. WTF??? Then they gave me a step by step procedure to make it work. Guess what, their procedures don't work. I went back to the manual and followed the procedures, and all is good and works mint. What I flipping mess this remote starter is. They have so many handouts that superceed the manual. Your in left field with this. May the force be with you.
Old Aug 24, 2011 | 09:48 PM
busboy4's Avatar
Glad you ultimately got it. I have had the same experience on many a project. Enjoy it.
Old Aug 27, 2011 | 08:42 PM
TNtech's Avatar
I can give anyone reading this a good piece of advice. If you get a Mopar kit that has ANYTHING electrical involved, ask your part counter person for any updated instructions. They can print them out for you. If I had a nickel......
DKats
May 27, 2021 12:58 AM
mikespassi
Nov 21, 2014 11:15 AM
KStar
Oct 3, 2013 01:18 PM
Raindrop
Feb 22, 2011 05:47 AM
RobertMunn
Jul 24, 2010 12:07 AM
