2007 Pacific battery reconnect problems
Old Jul 11, 2014 | 10:24 PM
ssdavies1's Avatar
Default 2007 Pacific battery reconnect problems
Hopefully this is an easy one for you guys. I disconnected the battery today to clean the terminals, and when I reconnected the battery, the display for the auto dual zone temp control is not showing the outside temp, and other data. Also, the info center on the left side of the instrument cluster seems to be stuck in compass mode. What's the problem?
Lately the car is not starting until after several key turns (which is what prompted the batt terminal work, they were a little corroded)...cleaning did not help...do I have a starter solenoid problem as well?
Old Jul 12, 2014 | 05:35 PM
ssdavies1's Avatar
The display issues are resolved, just needed to push the right buttons (operator error I guess). Starting issue unchanged, will look at that next....
Old Jul 14, 2014 | 09:32 AM
Shep's Avatar
Check the ground on the front left by the tranny. They get corroded really bad and need to be cleaned and sometimes replaced.
Old Jul 14, 2014 | 09:34 AM
Shep's Avatar
Also the key fob battery might need to be replaced. I had to replace the whole key on the wife's car then have Chrysler flash it so the security (SKRIM) would read the key.
Old Jul 14, 2014 | 09:05 PM
ssdavies1's Avatar
Visual inspection looks ok. Will get the tire off this weekend. Thanks.
ssdavies1's Avatar
Ok, thanks...
ssdavies1
Jul 14, 2014 09:08 PM
spd800
Aug 22, 2007 08:20 PM
sumncguy
May 12, 2007 03:24 PM
paul barr
Feb 6, 2007 06:05 PM
5point7
May 26, 2005 07:40 PM
