2007 Pacific battery reconnect problems
Hopefully this is an easy one for you guys. I disconnected the battery today to clean the terminals, and when I reconnected the battery, the display for the auto dual zone temp control is not showing the outside temp, and other data. Also, the info center on the left side of the instrument cluster seems to be stuck in compass mode. What's the problem?
Lately the car is not starting until after several key turns (which is what prompted the batt terminal work, they were a little corroded)...cleaning did not help...do I have a starter solenoid problem as well?
The display issues are resolved, just needed to push the right buttons (operator error I guess). Starting issue unchanged, will look at that next....
Visual inspection looks ok. Will get the tire off this weekend. Thanks.
Ok, thanks...
5point7
May 26, 2005 07:40 PM
