2007 Pacifica front blower running with head unit removed
Old Aug 2, 2014 | 07:34 PM
imnotmarvin's Avatar
Default 2007 Pacifica front blower running with head unit removed
I have a 2007 Pacifica with ATC. The front blower motor stopped running over the winter. I replaced the blower motor control module and that fixed the problem for about a week. Then the blower went to high speed and only shuts off when the car is shut off. I tried another module and got the same thing immediately at install. Both parts are aftermarket from chain auto parts stores. I can shut off the unit itself with no change to the fan speed. I am able to operate the rear system fine from the control unit. The blend door operates as it should. The heat and A/C all work fine. The only problem is the blower stuck on high. I have 12V on the harness coming into the module and have continuity from the ground wire to metal. I have swapped relays in the fuse block and can feel the relays open and close when the ignition is turned on. So my diagnoses goes a little further now than some of the others I've read.
I know there have been a few posts regarding the front blower running on high with the system off. I've read them all multiple times in trying to fix this problem. I have replaced the blower motor module twice on this vehicle and moved on to trying to see if the control unit itself might be bad. I was told that if I removed the unit and the blower stopped, the control unit was bad. I didn't see anywhere what the problem might be if I removed the control unit and the fan continued to operate. I have the unit completely disconnected and sitting on the passenger seat and STILL the blower runs. Any ideas? Could it be yet another bad module?
Thanks for any help.
len115566
Cirrus & Breeze
Jul 17, 2010 09:23 PM
Markmysite
May 21, 2010 10:06 AM
williamknitter
Nov 25, 2007 08:47 AM
daveandtara1
Jun 7, 2007 04:55 AM
Stealth450r
May 30, 2007 02:31 AM
