3.5L motor/tranny issues....Feedback please
Old Feb 11, 2008 | 11:12 AM
Fonzie's Avatar
Default 3.5L motor/tranny issues....Feedback please
Looking at an '04 w/ 48,5k. I'm hearing from some others that the 3.5 has had probs with oil pump failure/narrow oil journals that clog up, causing spun bearings & engine seizure. Is this motor the same 3.5 that's in the Intrepid, that I hear there were so many issues with?
Also hearing the tranny's are notorious for going bad before 100k, and that there are recalls issued for starter problems (car sporadically won't start....even when new)
Any truth to either of these things? Thanx in advance for your feedback!
Old Feb 11, 2008 | 09:43 PM
Default RE: 3.5L motor/tranny issues....Feedback please
ahhh no u got the wrong engine and I have not seen any recalls for starter issues. as for the tranny I own a 98 same body style and I ahve 179k on it same 2.7 engine and same tranny.
Old Feb 13, 2008 | 06:51 PM
jamie1's Avatar
Have to agree with Chrysler tech. You are thinking of a different engine. This engine has been around since 93 and has been bullet proof for Chrysler. Early ones had water pump problem,but that was corrected in 98 when the block when from cast iron to aluminum. True,Chrysler has had their fair share of trans problems,but that too has for the most part been corrected a few years ago. With Chrysler transmissions,you must use the proper fluid and that is ATF+4.
Old Feb 13, 2008 | 10:31 PM
master tech's Avatar
The engine that Fonzie may thinking about is the 2.4 L in the PT. The crankshaft are walking in the block, causing the front oil seal from the oil pump to leak. Also stratus body too, with the 2.4 L.
Old Feb 14, 2008 | 08:45 AM
moe's Avatar
moe
again,these guys are right on the money!!moe
Old Feb 19, 2008 | 05:15 PM
Fonzie's Avatar
Wellllllllllll.........bit the bullet, so hope you guys are right, and that the other stuff I'd heard about this motor isn't true! Bulletproof.....I LIKE the sound of that!!
davekro
Jul 7, 2014 04:17 PM
laragtop
Dec 17, 2011 10:55 PM
Aquintesce
Apr 6, 2010 12:47 PM
mikeyboy
Apr 9, 2008 08:43 PM
ssstw1
Jan 21, 2008 04:34 PM
