3.8 cam crank correlation
Old Aug 29, 2015 | 07:49 PM
Turboblackbird's Avatar
Default 3.8 cam crank correlation
06 Pacifica 3.8. Starts and runs on all 6 but is running like timing is retarded. Cam crank correlation is -26°. according to my DRBIII. Replaced cam sensor with oem one and performed relearn procedure with the same result. Used a pico scope on both cam and crank signals and had a good pattern. Customer states it has been this way since having the cradle replaced. Yes I checked the grounds. Anyway, without checking the actual timing marks does anyone have a clue? Thanks so much!
-Jerry
RonT
Apr 2, 2015 10:21 AM
rabbitz
Aug 11, 2012 04:20 PM
kazeck23
Feb 16, 2011 10:05 AM
leeb
Oct 27, 2009 12:28 AM
BigBlocksnHardrock
Apr 7, 2007 12:19 PM
