ABS and brake light ECU internal failure
Old Feb 6, 2021 | 06:00 PM
04_pacifica's Avatar
Default ABS and brake light ECU internal failure
Scan tool shows the correct wheel speed for all 4 sensors..
was wondering if there is a common problem with these or the wiring at some location? I know these cars have ground problems, and was wondering if any relate to the ABS?
also wanted to confirm if i replaced the module with used, would need the dealer to flash an update to the vin/serial numbers or something?
oh and i wanted to confirm that there is a wire that goes from the module to the BCM? i've read someone had a problem with that wire.. but it might have been the town and country.
Old Feb 6, 2021 | 06:01 PM
I don't see the edit button.. i wanted to add that i just remembered that the traction control light comes on sometimes..
Old Feb 7, 2021 | 07:46 PM
ggoose's Avatar
What is the actual obd code you are seeing?
skid2964
Jun 22, 2022 08:11 PM
silenttundre
Nov 10, 2020 07:39 PM
leukon777
11
Apr 18, 2015 09:17 PM
alexyoung59
Oct 7, 2011 04:59 PM
Gasman
Jan 24, 2011 12:23 PM
