ALL Warning Lights are On
Driving on the highway today, a snowstorm with very wet roads (may be important), ALL of my warning lights came on. The radio powered off, the climate control powered off, front wipers off, rear wipers on, speedo off, gas gauge on, lights on,... almost everything off except the car kept running. I stopped for a bit and turned the car off, then turned it back on and most lights went off except the check engine (which could be loose gas cap, etc.). Drove another 40 miles and it happened again. When it happens the car shifts very rough in lowwer gears. Warning lights included:
* ABS
* Check Engine
* Traction Control
* ESP BAS
* Tire Pressure Monitor
* some lightening bolt looking thing - not sure what is exactly
* and others I am forgetting at the moment
I suspect that there is water somewhere it should not be, and this will self-correct. Before I take it to the dealer to start looking if the lights do not go off, I wanted to see if anyone else has seen this and have any ideas the cause.
It is a 2007 Pacifica, AWD, 4.0L, with 117,000 miles on it. Runs great, no major problems with it ever...
Thanks in advance,
Scott
* ABS
* Check Engine
* Traction Control
* ESP BAS
Thanks in advance,
Scott
Drive Safe and Enjoy!
Lonestranger
G
wcedeno
Feb 26, 2011 10:03 AM
bgborden
Mar 7, 2010 09:15 AM
mjmangus
Dec 8, 2009 10:17 AM
Johnbush1
Feb 22, 2008 04:00 AM
