Alternator or Pulley?
Old Feb 10, 2016 | 02:21 PM
Tibby's Avatar
Default Alternator or Pulley?
I have a 2007 Pacifica. Recently just started to make some whining noise when the car starts. from the inside it sounds like a bearing problem, but I cant tell if it's coming from a pulley or the alternator.
Can someone suggest a way to test if its a pulley or the alternator bearing makes the sound?
Old Feb 10, 2016 | 04:13 PM
use a stethoscope
Old Mar 16, 2016 | 12:55 PM
neex's Avatar
lift the belt tensioner with a 3/8 ratchet and remove the belt off the alternator pulley... spin every pulley by hand and see if any have any play... although not a perfect way to diagnose, you will definitely be able to feel grinding or play easily enough... if any grind or move laterally they need to be replaced...
Old Mar 23, 2016 | 01:39 PM
UFGatorsDM's Avatar
I had a similar issue not too long ago, was gonna get a stethoscope to try and find the source, but kept forgetting to get it. coincidentally a few weeks later my alternator died on the highway at 2am. had it towed home, replaced alternator, whining is gone. Also it doesn't hard shift in between 2nd-3rd gear anymore.
Old Mar 24, 2016 | 05:03 AM
neex's Avatar
ringing indicates dry/hardened grease or damaged races/bearings... if you are extremely careful, you can likely remove the pulley and 'service' the bearing, replace the bearing or easiest yet is to buy a new pulley. When I thought my alt pulley was out (even using a stethoscope) it ended up that my idler pulley was the culprit. I experimented with replacing the bearing, servicing the bearing and replacing the whole pulley as I did the lower idler and tensioner bearings also. All of the above are similar solutions depending on skill and resources/time. You will be amazed if you check the grease hardening - it may look/feel like plastic!
Pop45
Aug 15, 2014 03:26 PM
Pop45
Jul 16, 2014 10:01 AM
estrika
14
Mar 29, 2014 08:53 AM
skdacci
Sep 28, 2012 12:29 AM
Constant
Oct 30, 2011 11:48 PM
