Ambient air temperature sensor
Old Jun 13, 2023 | 01:10 PM
ryano2121's Avatar
Default Ambient air temperature sensor
My wife has torn up the front of her Pacifica pretty well over the years. I had a CEL come on, ambient air temperature sensor. The exterior temperature hovers around -37*, the sear heaters automatically turn on, and the AC is not cold.
I replaced the sensor and left the negative cables off both batteries with the headlights on for a couple hours. When I started it, everything appeared normal again. But when I drove it later, the CEL came back on, the exterior temperature is wrong, and the AC is not cold.
I check the two wires from the sensor as far as I could and did not find any issues.
The original sensor showed 12 ohms of resistance and went down when I heated the sensor with a hairdryer.
The new sensor showed 26 ohms and also went down when heated.
What else could be going on?
utahkat57
Jan 21, 2022 06:07 PM
Z3Roadster
Dec 10, 2015 03:50 PM
robwill
Mar 15, 2011 03:50 PM
screamingskull
Mar 5, 2009 12:08 AM
deathmagnetic
Sep 16, 2008 01:24 PM
