antifreeze leak
Old Apr 11, 2008 | 09:36 AM
gbeach's Avatar
Default antifreeze leak
2006 pacifica 3.5l, leaking antifreeze below drive belt, also cooling fans coming on as soon as you start the car. need help
Old Apr 13, 2008 | 05:22 PM
jamie1's Avatar
Default RE: antifreeze leak
Coolant leak is most likely the water pump. It is driven by the timing belt. There is also a plate on the RH head that has O rings on it that can leak[rare]. Rad fan running all the time could be a couple of things. Defective relay,defective PCM,defective temp sensor,short in the wiring.
Old Apr 20, 2008 | 03:59 PM
gbeach's Avatar
jamie1,
thanks for responding. question, I just bought the dealers service manual, and it says when replacing the timing belt to also take valve covers off and loosen rocker arm assy. I have done timing belts before, but I have never had to do that. It is the 3.5l, and I am wondering if it is really nec.
any help is deeply appreciated.
Greg
Old Apr 20, 2008 | 06:11 PM
moe's Avatar
moe
hey G here you go i'll send send pictures,moe
3.5L ENGINE
The water pump on all models can be replaced without discharging the air conditioning system.
WARNING: DO NOT REMOVE PRESSURE CAP WITH THE SYSTEM HOT AND UNDER PRESSURE BECAUSE SERIOUS BURNS FROM COOLANT CAN OCCUR.
NOTE: It is normal for the water pump to weep a small amount of coolant from the weep hole (black stain on water pump body). Do not replace the water pump if this condition exists. Replace the water pump if a heavy deposit or a steady flow of engine coolant is evident on water pump body from the weep hole (shaft seal failure). Be sure to perform a thorough analysis before replacing water pump.
[ol][*]Drain cooling system (Refer to 7 - COOLING - STANDARD PROCEDURE).
NOTE: The water pump is driven by the timing belt. [*]Remove engine timing belt (Refer to 9 - ENGINE/VALVE TIMING/TIMING BELT/CHAIN AND SPROCKETS - REMOVAL).[*]Remove water pump mounting bolts (Water Pump - 3.5L Engine). Note position of longer bolt for proper re-installation.[*]Remove water pump body from engine (Water Pump - 3.5L Engine). [/ol]
Old Apr 20, 2008 | 06:14 PM
moe's Avatar
moe
hey G this pretty big my friend,the engine is not free wheeling so you need to be real careful withe the timing.heres what pump looks like.moe
Old Apr 20, 2008 | 08:56 PM
indept's Avatar
Hey Moe, just curious, how long do they give for a the water pump in hours?
Old Apr 21, 2008 | 10:19 PM
jamie1's Avatar
Oddlyenough,the ALLDATA labour guide says the water pump pays 3.0. And a timing belt pays 3.1 hrs. I would estimate the labour if I was doing the job at.4.0 hrs.
RÖENTGEEP
Aug 8, 2012 11:27 AM
Jerry32
Jul 13, 2011 08:43 AM
RayDog26
Nov 6, 2008 02:33 PM
romoakatruebeast
Aug 8, 2008 10:41 AM
ronryben
Jul 13, 2006 03:48 PM
