Battery warning light
Old Aug 21, 2020 | 03:24 PM
JDNAIL1@AOL.COM's Avatar
Smile Battery warning light
Hi Guys,
New member I was was wanting to know that when the battery light comes on and off intermittently could it be the voltage regulator or the alternator. If so how can you tell the difference.
Old Aug 21, 2020 | 08:21 PM
the pcm is the voltage regulator
Old Aug 23, 2020 | 02:11 PM
Hi Super Member,
Im sorry but not quite sure what the pcm is or means
Old Aug 23, 2020 | 02:12 PM
Super Moderator I mean
Old Aug 23, 2020 | 07:48 PM
Power train Control Module basically the Engine computer
Old Aug 24, 2020 | 10:38 AM
Thats whats making the battery light come on
Old Aug 24, 2020 | 06:50 PM
faulty PCM a wire issue an alternator take your pick any one will cause this. Do some testing and see which one it is. OR take it to a shop let them use there tools to test and see whats the issue.
Old Aug 25, 2020 | 07:17 AM
FIREM's Avatar
Keep it simple, A loose/worn alternator belt could cause intermittent battery light. Also check and clean all battery B+ and Ground connections.
PCM's rarely fail and Alternators are pretty robust on these cars. Trouble shoot and repair as needed. Don't just throw parts at it.
Old Aug 28, 2020 | 04:22 PM
ZoeSkinner's Avatar
As ususal
DCMoose48
Apr 19, 2018 08:37 AM
wfballard
Aug 5, 2012 02:51 PM
hodgel@rlc.edu
May 5, 2011 10:25 AM
billyd10
May 3, 2011 05:41 PM
thumber82
Apr 8, 2007 08:38 PM
