Blinking odometer and clicking sound
Old Nov 2, 2008 | 11:54 PM
etozion's Avatar
Default Blinking odometer and clicking sound
I just bought off-lease 2005 Pacifica in grate shape. I never had a Chrysler car before.
I noticed that the "Check Engine" Light is on with “gas cap” message. I decided to read and reset trouble codes by following a post I found on one of the Chrysler forums: depress odometer reset button, turn key to on position, release button. I tried it several times and may did something wrong, but instead of codes I’ve got messed up computer that started blinking dash lights including odometer. The odometer is blinking even with key off. I can not start my car anymore. No crank at all. Because constant blinking and clicking relay in the fuse box I had to disconnect battery.
Have you experienced anything similar and know what to do to fix this problem?
Old Nov 6, 2008 | 02:38 PM
PacificaBus's Avatar
Default RE: Blinking odometer and clicking sound
How long did you disconnect the battery? Try disconnecting it for 15 minutes or so. The system should reset and check everything and obviously make sure your gas cap is tightened. If you still have a problem you might have to bring it to the dealer unless someone else here can help you.
Old Nov 6, 2008 | 06:57 PM
etozion's Avatar
I disconnected battery for over 24 hrs already. It did reset codes, but did not fix the problem. I still can not start my car. Just light clicking sound when I try to start the engine.
My friend told me to check the battery first if it's not dead, but if battery is good it will be difficult to troubleshoot.
I really do not want to tow my car to a Chrysler dealership.
Old Nov 22, 2008 | 09:02 PM
etozion's Avatar
Update.
It was dead battery. I replaced the battery and can start engine now, but can not switch transmition to drive position
doughy
Sep 25, 2022 11:42 AM
LizS.Soto
Nov 6, 2012 04:35 AM
CavVet
Mar 25, 2012 01:00 AM
KMusTeach
Apr 9, 2008 02:55 PM
jessestaton
Dec 27, 2007 10:29 AM
