Check Engine Light
Old Sep 24, 2007 | 01:09 PM
Ldp1959's Avatar
Default Check Engine Light
Hello,
My check engine light is on, when I had it diagnosed he said it read "cylinder 5 misfire". Should I be looking for anotherproblem besides plugs/plug wires??? Is replacing the plugs and wires a major undertaking? I can't see the plugs, I imagine they are under the plenum...somewhere. lol
Thanks!
Old Sep 24, 2007 | 09:43 PM
jamie1's Avatar
Default RE: Check Engine Light
You mean you just had the code "scanned". A diag would have pin pointed the problem. Cyl missfire could be a plug,coil,injector,vacumm leak,broken valve spring,burnt valve or even wiring problems.
Old Oct 2, 2007 | 01:20 PM
Ldp1959's Avatar
OK,
I took it to the Chrysler dealer. Theyperformed the "diagnostic". Said it was plugs, so I had them replace the plugs, $160.00. That night the light went on again. I took it back, they performed the "diagnostic". Said it was the coil, so I had the coil replaced, no labor charge, but still another 61.00. That was yesterday. Today, on the way home from work for lunch, the light comes on again.This is hardly any better than the scanning I had done earlier. The problem is still not pinpointed, I am out over200.00 and still have the problem. Does anyone have any ideas?I am concerned with the inability to properly diagnose the problem.
Old Oct 2, 2007 | 03:47 PM
mario65's Avatar
Hi i will check compression on your cylinder, that might be the problem.
Old Feb 6, 2008 | 10:22 AM
harry's Avatar
I am experiencing the same check engine code , what was the eventual fix
Old Feb 6, 2008 | 11:24 AM
moe's Avatar
moe
hey 1959,i know that engine has trouble with the valves.there is a tsb for rotating the valve springs and a group of other valve related problems.heres the tsb #09-010-06.have your dealer pull this up by your vin number make sure it applies.moe
qbasicer
Sep 25, 2012 02:58 PM
RobinVA
Jan 5, 2010 10:18 PM
cacarrollsr
Cirrus & Breeze
Nov 11, 2006 10:47 PM
teresadogg
Nov 2, 2005 03:21 PM
ChryslerNamedTrixie
Oct 20, 2005 03:06 PM
