Cleaning Pacifica's Throttle Body
Old Nov 20, 2008 | 09:06 PM
rollingrock's Avatar
Default RE: Cleaning Pacifica's Throttle Body
ORIGINAL: dcotter0579
If you put it all back together correctly, the light should go out after a few trip cycles, ie, start, warm up, shut off, cool down.
If you don't want to wait, go to Autozone and have them hook up their OBD scanner. Be sure to grab any codes before clearing in case something else is going on.
Light went off today, thanks again for the info, this was a fun project...mostly bc my wife called several times today to tell me how much better the car was driving and the pedal wasn't sticking anymore.
Cheers
Old Mar 23, 2009 | 08:14 PM
chterryiv's Avatar
Thumbs up Thanks
Thank you so much for the info. I was able to do this job in 20 minutes and I have almost zero experience with an engine. It was amazing how much black carbon was in there. I am very happy to know that this forum exists. Much appriciated.
Old Sep 23, 2009 | 12:11 AM
autoupgrades's Avatar
Originally Posted by moe
pretty straight forward.take a can of carb cleaner spray it on a rag.open the blades (picture #1)and wipe out black build up.
What is the name of #3 part?
Old Jan 24, 2010 | 08:45 PM
Weekend Wrench's Avatar
Default Gas Pedal Sticking
Very easy fix. Just used orange cleaner from the kitchen and some Q-Tips. Funny how Firestone and Chrysler service can't figure this one out...
Old Jan 24, 2010 | 08:59 PM
  #15
whats the fix? this is a maintenance item
Old Jan 25, 2010 | 06:05 AM
  #16
daniel58's Avatar
Default cleaning throttle body
How does one open up the blades in picture #1 as it seems they will not retract as it appears the blades are electrically activated.
Or does one rotate the cam which is the gas throttle to rotate the blades allowing one to directly rotate the blades?
As it does look like it might be directly connected to the blades; at least that is what it looks like in the pictorial picture.
Old Jan 25, 2010 | 06:52 AM
  #17
see that big spring on the right this is still a manual system u press on the gas the buttery fly moves open the things on teh side are a TPS and an IAC motor nothing electrical about this throttle body.
SpudlerT+CTouring
Feb 2, 2012 01:05 AM
15951a\
Dec 18, 2011 08:22 PM
Discovering06
Jul 7, 2011 09:10 AM
3.3lxbluevan
Dec 9, 2008 08:55 PM
lerry1957
Mar 21, 2008 09:36 AM
