Heater blowing cold
Old Mar 25, 2008 | 11:25 AM
nypacifica's Avatar
Default Heater blowing cold
I have a 2005 Pacifica with auto dual zone air. The heater works intermitently out of the front vents and almost always only blows cold out of the back vents. I have tried playing with all the settings and nothing seems to fix it. Any suggestions? Thanks!
Old Mar 25, 2008 | 01:19 PM
mrfixit454's Avatar
Default RE: Heater blowing cold
Have you tried turing the auto portion off and controlled it manually?
Old Mar 26, 2008 | 07:16 AM
RAHollis's Avatar
2007 Pacifica Touring: All last summer the climate control was on recirculate every time I started the car, contrary to what the owner's manual states. On one 80 degree day, it was blowing roasting hot from everywhere. In winter, with the temp set at 67 to 70 my feet usually freeze. Suddenly a blast of hot air comes from the defroster. At other times the interior is freezing. Last Sunday the ambient temp was 34 and the controls were set on 70. I literally froze. It does not matter if it is on auto or manual. Three dealers have stated that the climate control is operating as designed.
Old Mar 26, 2008 | 03:30 PM
mrfixit454's Avatar
Another problem arises if you are holding a hot cup of coffee in your right hand while driving. The IR sensor (or what ever type it is)on the dash picks it up and thinks you are hot and tries to cool the car.. while in auto mode of coarse. Not that this is your problem but it can be a problem.
Old Mar 27, 2008 | 08:11 AM
nypacifica's Avatar
I have tried it in both manual and auto mode. Now it doesn't blow any heat, front or back. What could be causing this.
cfa0703
Jun 3, 2013 09:45 PM
AussieAspen
Sep 7, 2011 08:37 AM
rowl3y
Feb 27, 2011 10:20 AM
Chrysler300MSpecial
Dec 6, 2009 07:51 PM
glock 40
Apr 30, 2008 10:58 PM
