Crank but no start
Old May 21, 2022 | 03:58 PM
06 pacifica's Avatar
Default Crank but no start
I have a 2006 pacifica we were driving down the road when it acted like it was out of gas it has 3/4 of a tank of gas and died. Towed it home now it wont start it cranks but wont start. I checked fuel lines im getting fuel to the engen. Im not realy a car guy but im trying do you guys have any ideas?
Old May 22, 2022 | 06:47 PM
stephenjxn's Avatar
A failing fuel pump is one of the faults that can cause this. Other likely problems would be the battery, alternator, battery cable, wiring harness fault, crank, or camshaft position sensor. The fuel pump may have to be replaced because it was not turning on. Just my 2 cents
Old May 22, 2022 | 06:48 PM
stephenjxn's Avatar
A failing fuel pump is one of the faults that can cause this. Other likely problems would be the battery, alternator, battery cable, wiring harness fault, crank, or camshaft position sensor. Just my 2 cents. Are you able to retrieve any fault codes?
Old May 23, 2022 | 02:23 PM
Default Reply
repl
I checked all the pumps and filters. I have traced it to faild water pump but i cant get the outer crank pullie off any advice i have a puller but cant get it to work and im affraid of breaking it
Old May 24, 2022 | 09:24 PM
what puller are you using ? there is a certain one that is used for that balancer
Old May 25, 2022 | 08:15 AM
ggoose's Avatar
I am not aware of how a failed water pump would prevent an engine from starting. If you have the 3.5l, the water pump is driven off the timing belt. Is it possible the timing belt has broken? Would you be able to explain how you came to this diagnosis?
BGHobbs
Jul 19, 2021 12:14 PM
Joe Scalesse Jr.
Nov 27, 2019 08:36 AM
Owensg
Feb 8, 2019 09:00 AM
cliff1968
Dec 10, 2017 02:01 PM
dcraig10004
Aug 23, 2010 08:47 PM
