Run out of gas & wont Start
Old Feb 7, 2019 | 05:23 AM
Owensg's Avatar
Angry Run out of gas & wont Start
Hello Everyone, i run out of gas in my 2000 Chrysler town & country van after refilling the van wont start. The fuel pump is workng well. Please what can i do.
Regards.
Old Feb 7, 2019 | 09:26 AM
REBEL59's Avatar
Regards.
Did you try cycling the key to the run position(just dash lights, NOT crank) and wait for the fuel pump hum (about 3 seconds) and do it again, then give a SHORT crank. Then repeat the process, this will let the pump refill and pressurize the fuel lines to be able to start.
Other than that, you could try a short spray of starting fluid into the air intake.
Old Feb 7, 2019 | 11:56 AM
Owensg's Avatar
Yes i did cycling the key to the run position(just dash lights and wait for about 4seconds(4) before i crank. still did not start.
Old Feb 7, 2019 | 12:44 PM
REBEL59's Avatar
Did you do it more than 1 cycle as your reply seems to indicate? Having run out of fuel, it takes a few times as I posted before trying to crank it over to start. There is a lot of fuel line to fill from the tank to the motor. If I'm not mistaken, there is a Schrader valve (test port) on the injector rail, you could take the stem cap off and press the valve(just like a tire valve stem) and see if any fuel sprays out. IF none does, then the pump has not moved enough fuel thru the lines yet.
Old Feb 8, 2019 | 07:58 AM
Owensg's Avatar
I did 4 circles before cranking and I’ve also press the schrader valve on the injector rail. There is fuel splashing out from the valve. i have repeat this process for a 2 days still wont start.
Old Feb 8, 2019 | 09:00 AM
REBEL59's Avatar
It would be helpful to know what size motor is in the van. And ANY other background performance "issues" it may have been having before this "run out of gas" situation happened. Has the CEL on the dash been on? IF you are getting fuel, then you must not be getting spark.
Did you try a small shot of starting fluid into the intake and see if it would fire off on that, as I initially posted?
pheel85
15
Nov 11, 2015 05:14 PM
cindy121087
Mar 21, 2012 01:34 AM
dcraig10004
Aug 23, 2010 08:47 PM
darlon
Apr 19, 2010 06:19 PM
johno
Feb 21, 2008 02:32 PM
