Crankshaft sensor location
Old Dec 22, 2019 | 02:33 PM
2007Pacifica4L's Avatar
Question Crankshaft sensor location
Can anyone describe for me where I can find the crankshaft sensor on a 2007 Chrysler Pacifica V6 4.0L? A photo or a drawing would be fantastic. I have been searching forever without much luck!
Thank you so much!
Steven
Old Dec 22, 2019 | 04:34 PM
here ya go
File Type: pdf
Old Dec 23, 2019 | 08:29 AM
Thank you so much for that!
What about the camshaft position sensor? any chance you would have a drawing showing its location on the same car? 2007 Pacifica V6 4.0L. It seems the web is inundated with information on the 3.5L, but not the 4.0L. Weird
Thank you,
Steven
Old Dec 23, 2019 | 11:52 AM
cam sensor is next to the alternator
Old Dec 27, 2019 | 05:24 PM
Thank you so much for your reply Chrysler Tech, I will look for the cam sensor tomorrow. I have a follow-up question if I may... As I described earlier, I have a 2007 Chrysler Pacifica 4.0L with 130,000 miles but a replaced engine about two years ago with about 65,000 miles. The car will turn and turn, so a tech friend came with his Snap On diagnostic tool which it seems did not get much out of it. He used starting fluid and the engine backfired, then after some further testing, he realized that there is no current going into either the coil or plugs (I cannot remember) so he suggested that the problem was the crank position sensor, but after replacing it, the car is still doing the same thing. So I thought that I should replace the cam position sensor as well. Any suggestions that could help me fix this car?
Thank you so much for your help!
Steven
Old Dec 27, 2019 | 07:40 PM
so will not start up at all or takes awhile to start up?
Old Dec 27, 2019 | 07:55 PM
It will not start at all!
kelcig69
Mar 24, 2017 10:32 AM
Mrbrucie22
Dec 15, 2014 08:16 PM
the_one_comp
Mar 7, 2014 05:08 AM
funjon1
Jun 25, 2008 07:01 PM
rwcrazy
Jul 20, 2007 01:30 PM
