Help with swapping Transmission Oil Cooler
Old Jul 6, 2013 | 12:24 PM
clearwaterblue's Avatar
Default Help with swapping Transmission Oil Cooler
I am new to this forum and am hoping I can find some help. I'll start by saying I am not a mechanic but am technically apt. I recently crashed my 2005 Pacifica (touring - 3.5l engine) and smashed the radiator along with the A/C condenser and the transmission cooler. I'm replacing it all myself.
I ordered all my parts online from ebay except the condenser which I got at a salvage yard.
The trouble I'm having is with the Transmission Cooler Lines. I took off the old lines and was about to put the new lines on when I noticed that the old transmission cooler and the new one do not have the same connectors. I'll put some photos in here at the bottom so you can see the difference.
The old cooler had a nut on the line that was held on with a pin and attached directly to the cooler. The new cooler has what looks like a place for a rubber hose to attach.
Like I said, I'm not a mechanic and this is likely something silly that I am overlooking but I need some help figuring out how to connect the lines to the cooler.
Please help as I am utterly confused and I have googled to my hearts content and can't find any guides on replacing the cooler. Thanks in advance!
New Cooler
Old Cooler Connector (Broken)
Old and New Together
The lines and the new connector
Old Jul 6, 2013 | 07:50 PM
Djinn-n-Tonic's Avatar
Just swap the Fittings. They unscrew.
aspen13
Dec 23, 2013 05:49 AM
thx569
May 24, 2011 01:18 AM
onecheck
Mar 3, 2011 09:43 AM
djohn
Aug 16, 2010 09:04 AM
WpgGlen
May 2, 2008 10:38 AM
