Instrument Cluster Dark & Remote Lock Failure
Old Jul 19, 2012 | 06:07 PM
brian3's Avatar
Originally Posted by gcartrim
My wife just got back and I had a chance to look at the car. Everything worked fine after she got gas and restarted the car. I unplugged the battery to turn off the engine check light. I checked all the wiring around the control module under the dash and also checked all the fuses and relays under the hood. There seemed to be quite a few that were loose and dislodged a bit also. The ignition switch seems to be pretty loose also, there is a lot of slop in it. I am wondering if maybe this could be the problem?
Brian did you ever have the problem come back at all? We have 90,000 on the odometer BTW.
I had it happen a few times since. It seems related to how fast I turn off the car and open the door and get out. It seems to occur when I do this quickly while in a hurry. My guess a software issue. Every time if recovers after 5 minutes or so and the check engine light goes out after a few on/off cycles.
clt72pilot
Sep 6, 2016 05:19 AM
agravitt
Jun 2, 2015 10:17 PM
landispa
Mar 1, 2013 01:01 PM
ringalori
Apr 1, 2009 11:37 PM
jlboan
Jul 26, 2008 09:28 PM
