Voyager/Caravan 1996, instrument cluster...
Old Mar 25, 2009 | 01:26 AM
ringalori's Avatar
Default Voyager/Caravan 1996, instrument cluster...
I have the next problem with the Voyager 1996:
- not working instrument cluster, all the gauges at zero, no diyplay for distance or trip
- not working wiper intermittent (wipers stops on the top or center of windshild, do more then one time... )
- not working speed control (tempomat)
But, sometimes when driving, the instrument cluster start working and also the wiper in same time.
I have already check the fuses, relays, conectors, remove the BCM and reinstal, resolder conector on instrument cluster panel, put the ground (-) wire direct to pin 7 on instrument cluster conector because I do not found the ground G200.
Any idea?
Old Mar 25, 2009 | 09:11 AM
Merlin's Avatar
Remove the heater control panel and check the 21 pin plug on that for melting.
Old Mar 26, 2009 | 01:42 PM
ringalori's Avatar
All the pins and wires in the 21 pin conector looks fine!
Any other idea? What else should I check?
Old Apr 1, 2009 | 11:37 PM
ringalori's Avatar
I have disconect the clockspring and the same result. Instrument cluster not working, tempomat not working and if I put on wiper intermittent wiper stops if I turn it off.
clt72pilot
Sep 6, 2016 05:19 AM
jtg61
Jul 19, 2012 06:07 PM
nealg58
Aug 24, 2011 03:53 PM
thomascathybell
Jan 18, 2011 05:09 PM
jlboan
Jul 26, 2008 09:28 PM
