Instrument cluster stays lit with key removed
Old Jun 23, 2009 | 09:58 AM
clt72pilot's Avatar
Default Instrument cluster stays lit with key removed
I have a 2004 AWD Pacifica. We havent driven it much lately and during the torrential rains it got wet inside. I believe the sunroof leaked. I tried starting it and the battery was dead. Jump started the car and it ran fine except the Nav will not come on. I tried ejecting the Nav DVD in the back and it wont eject. Pulled the fuse and it looks good. Turned the car off and the instument cluster stayed illuminated. Went back to the car 30 mins later and battery was dead. Jump started it again. Cluster stayed illuminated again on shut down. Disconected the battery and charged overnight. The next morning started the car and when I turned it off the cluster shut down slowly. 1st the fuel guage went to empty, then the engine lights came on, then the cluster finally all went dark. It acted like a slow relay to me. Now it seems like when the battery is fresh off the charger the cluster goes out slowly and when its weak the lights stay on until the battery is dead. No other lights on in the car. The Nav feature is still dead. Any ideas before it goes to the dealer with gremlins and the clean out my wallet.
Old Jul 2, 2009 | 10:19 AM
clt72pilot's Avatar
Default update
Took the car to Chrysler. They said "Checked codes had code for IOD open. Checked IOD fuse. Fuse good. Scanned cluster, code for internal failure. Cleared codes, checked battery, good volts, Recommend replace cluster, customer decline repairs." They wanted $1524 to replace the cluster and I'm not sure that will take care of the problem. Key Fob doesnt work, Nav doesnt work, tailgate doesnt work. However the cluster does go out when I remove the key now. One small victory. The other A/c problem is a hole in the Evaporator, evidently a common problem. They wanted another $1282 to fix that.
My only question now is do you think replacing the instrument cluster will fix all the other problems? and if I replaced with a non-nav version (much cheaper) would everything but the nav work?
Old Feb 28, 2016 | 07:51 PM
Brilliance79's Avatar
What did you end up doing? I have the same exact problem. I don't want to junk it even thought I'm looking for something I can count on now. I'd like to keep the repair cheap and use it to trade in.
Old Sep 5, 2016 | 08:30 PM
pretend1955's Avatar
I have the exact same problem. Someone must have an answer!
Old Sep 6, 2016 | 05:19 AM
clt72pilot's Avatar
I bought a new cluster on ebay and it solved the problem. Sold the car a year later.
Vol 04 T&C
May 31, 2015 09:04 PM
jpenrose
Jul 21, 2014 03:14 PM
kelcan72
Jan 9, 2013 02:48 PM
mypacifica
Oct 26, 2009 08:06 PM
jlboan
Jul 26, 2008 09:28 PM
