INTERIOR LIGHTS PROBLEM
Old Dec 11, 2007 | 04:57 PM
SHAY101382's Avatar
Default INTERIOR LIGHTS PROBLEM
I have a '05 Pac and now the interior lights won't turn on when they are pressed but they still work when I open the doors or use the manuel switch on the steering wheel. My husband checked my fuses and they were all working. Does anybody know what this problem is?
Old Dec 11, 2007 | 08:20 PM
Default RE: INTERIOR LIGHTS PROBLEM
the dome or the reading lamps do not work correct? if yes possible BCM or M27 CKT is broken.
Old Dec 12, 2007 | 07:02 AM
SHAY101382's Avatar
Yes, and it's not just the front ones, it's all the reading lamps. Do you know how much that costs and is it something that my husband can fix? [sm=thanx.gif]
Old Dec 12, 2007 | 09:05 AM
cost no I dont know what BCM u have installed and possibly u wont be able to install the BCM and have it work correctly It has been awhile sence I have install a BCM on a PAC. The installing is not the issue its once installed and proraming it if required would be the issue.
Old Oct 31, 2009 | 10:57 PM
jpacific's Avatar
what is a bcm, i have the same problem in my 06
Old Nov 1, 2009 | 12:45 AM
mrfixit454's Avatar
try un hooking the battery for a few minutes or removing the IOD fuse for a few to kind of "reset" or "reboot" the module (s) and see if it works again. Might be a temporary or longer term fix. ON mine, the power locks would not work by remote, or hitting switches on the door. After pulling the IOD fude for a few minutes and putting it back in, the locks work fine now. this had been for 2 months now. The IOD fuse in in the use box and labeled so. Maybe fuse 24?
PrivateLine
Jul 30, 2014 11:54 PM
johnkaracalidis
Oct 11, 2009 01:18 PM
Johnbush1
Feb 22, 2008 04:00 AM
SHAY101382
Dec 12, 2007 09:40 AM
pt no lights
Nov 2, 2006 01:45 PM
