Jumped time
So i have a 2006 pacifica, and it has jumped time. Someone i have been talking to says that when it jumps time it bends the valves and im better off just replacing the engine so it ends up being the same. Its a 3.5. Im just trying to zee if anyone else has amy experience with this.
see***
Won't start and "jumped time"...it is a fabric timing belt, NOT a chain and an interference motor(Valves hit pistons). IF the engine spins real fast with no attempt to start(like there's no compression) you have probably got a broken timing belt and if this happened at driving speeds...a TRASHED motor.
When my 3.5 liter in the Intrepid died it just flat out stopped running, and would not restart after that, until I had replaced the timing belt.
Warning, if he decides to do the timing belt, be sure to replace all of the pulleys involved, the waterpump, and the tensioner. "DO NOT". for any reason, use any aftermarket parts, use MoPar only, or you risk having to do it all over again in a year. That was a common complaint of 3.5 owners who used aftermarket timing parts at the forum for LH owners.
