low beams stopped working (not HID)
Old Jun 20, 2008 | 09:11 AM
johnseattle's Avatar
Default low beams stopped working (not HID)
Can someone please give me some advice. The low-beams on my 2005 Pacifica have both stopped working. All other lights work normally. I have checked the bulbs and the BCM fuse. I put my voltmeter on the headlamp plug and was only reading 4v - that was with the headlamps switched on or off. I am figuring that it is either the ballast or the switch itself. Where is the ballast module located? Or does anyone have any better 'brighter' ideas (no pun intended).
Thanks in advance.
Old Jun 20, 2008 | 09:37 AM
United1's Avatar
Default RE: low beams stopped working (not HID)
I am not familiar with the headlights in a pac, but, unless they are HID I would not expect any type of ballast is being used. I would check the switch. Pull the switch out and check the voltage. I had a bad switch in my Durango, same symptoms. After tearing it apart I discovered I had burnt contacts.
Old Jun 20, 2008 | 09:58 AM
Thanks united1. I will take a look at it soon as the wife gets back form work. Do you know how much they cost...ballpark?
Old Jun 20, 2008 | 01:27 PM
United1's Avatar
NAPA online has 3 versions (with and without fogs, etc), pricing from $27 - $65.
Old Jun 20, 2008 | 02:11 PM
thanks again.
Big_Rob
Nov 25, 2012 12:17 PM
penniman16
Dec 10, 2011 03:52 PM
scott04
Dec 16, 2009 08:41 PM
johnseattle
Jun 20, 2008 07:47 PM
cgaeth
Jul 4, 2007 11:08 AM
