New tires - sensors reset?
Old Apr 21, 2009 | 10:25 PM
tcoxcsr's Avatar
Default New tires - sensors reset?
I just installed new tires on my '04 Pacifica. The old tires had less of a maximum air pressure rating than the new ones do. I am now getting a message on my tire sensors saying they are overfilled, when in fact they are filled to the appropriate amount for the new tires. The tires size is the same as the old ones, but they are a different brand.
The maximum pressure on the new tires is 51 psi. I think the old tires had a max of 44 psi.
Is there some way to reset this sensor for the new air pressure on the new tires?
Thanks in advance for any help you can give me.
Old Apr 21, 2009 | 11:07 PM
dont tell me u put 51 psi of air in the tires.
put 35 in no more no less. FYI when it says make amount of air like U are reading that means the tire will bust if u put more then that in there it does not mean u put that amount in there.
Old Apr 21, 2009 | 11:47 PM
tcoxcsr's Avatar
Default air pressure
When we picked up the car the light said "one tire high pressure". I asked the tire guy and he came out and let some air out. I think he had them at 44-46 psi. They are now at 40 psi all around. so if the tire says 51 psi max that doesn't mean keep them at 51 psi.
you are saying 35 psi is fine for these tires right? I always wondered what is the true pressure for a specific tire and why would the tire pressure change if the size is the same.
thanks for your help...
Old Apr 22, 2009 | 09:35 AM
SARG's Avatar
The ideal pressure for the "vehicle" i.e. Pacifica is 35 psi and that is the range the TPS (sensors) units are set for.
The pressure settings are always for the type vehicle and associated suspension ......
Old Apr 22, 2009 | 10:32 AM
SDHUSKER's Avatar
Cool Sdhusker
There should be a placard inside either the drivers door or the left rear door telling you the correct tire pressure. My 2007 Pac Touring says 33 PSI.
Old Apr 24, 2009 | 03:49 PM
PacificaBus's Avatar
You should always add what it is recommended for the vehicle, not for the tire.
Old Apr 24, 2009 | 10:26 PM
u guys are nicer then I am about this. How long have u been driving cars? geee.
1OLDMAN
Oct 8, 2019 01:54 PM
zipdrive
Jan 16, 2012 01:27 AM
coolguy64
Aug 11, 2011 08:55 PM
tCandGrandCaravan
Jun 2, 2011 09:31 AM
cwinship
Dec 13, 2006 03:34 AM
