No start after H2O pump and timing belt
Old Sep 11, 2011 | 03:53 PM
shaka38's Avatar
Default No start after H2O pump and timing belt
My water pump went bad. I replaced the pump and the timing belt while I was at it. I have 130K on it and did a tune-up at 120K, all but the timing belt. Now that I did the timing belt, the vehicle will not start. I have no fuel at the fuel rail, and it appears that there are no outputs from the PCM.
I've run an Actron scanner and seemingly anything from the PCM comes up as incomplete, i.e. any sensor involved in engine ignition, etc.
I'm at my wits end! The vehicle was running fine before but now no fuel. Is there a reset for automatic shutdown? Pulling B+ isn't cutting it.
Any suggestions anyone?
Old Sep 11, 2011 | 10:51 PM
Go back and check your timing make sure the engine is at TDC to start with
If it was running b4 the work was done and now its not U can bet its human error go look at everything again.
Old Sep 12, 2011 | 10:29 AM
shaka38's Avatar
Roger, Chrysler Tech,
Will do...I'm as frustrated as ever! I'm in the middle of a move to El Paso from WI. I was trying to prep the vehicle for SW Texas.
I appreciate your response.
lost-in-space
Cirrus & Breeze
Dec 5, 2014 10:36 PM
nonhemi1959
Nov 22, 2014 07:18 AM
binky42
Cirrus & Breeze
Jul 20, 2011 06:10 PM
montreal
May 7, 2008 10:59 PM
sebringphanatic
Mar 22, 2008 07:57 AM
