Now What????
Old May 2, 2012 | 11:30 AM
GibsonGuy's Avatar
Default Now What????
I wrote in a week or so ago regarding a Check Engine Light with a PO440 Code. I've replaced everything from the gas cap, Fuel Pump/ Level Unit (P/N 5101805AC) Fuel Pump Retailer Kit (P/N 5139088AA), as well as the EGR valve, and the check engine light is still on.
This morning I go to start the car, and every warning light on the dash lights up...emergency brake light, ABS light, Airbag light and more. You name it, it lit up. Radio/sound system will not power up. HVAC system will not turn on. Power windows will not work. I checked the battery to make sure the terminals were clean and tight. They are spotless and tight.
My Chrysler dealer is telling me that I now need a system "grounding module" at a cost of $650+. Does this make sense? Could this "grounding module" have anything to do with the check engine light that won't go off?
Old May 2, 2012 | 07:41 PM
TNtech's Avatar
Grounding Module...WTH ??
Are you sure they didn't say "Integrated Power Module"?
Look in the fuse box under the hood. Check Fuse #3 , Fuse #50 and find the relay labeled "Run Relay" and swap it with a known good one. The PO440 may be unrelated.
Old May 4, 2012 | 03:31 PM
GibsonGuy's Avatar
Now the dealer is telling me that the problem is the "integrated power module" and is telling me the parts alone are $1000 plus labor. Also that it will take "5 to 6 days" to get the part from Chrysler. Does this sound right, or am I being taken to the cleaners?
ShopSAR
Nov 7, 2007 08:15 AM
1 sick tsi
Feb 3, 2007 03:35 PM
Oct 14, 2006 06:02 AM
phunter
Jul 8, 2005 07:56 PM
