Oil dripping from bottom of ac compressor after freezing temps
Old Nov 17, 2019 | 05:34 PM
Shanfara's Avatar
Default Oil dripping from bottom of ac compressor after freezing temps
I have a 2006 Pacifica 3.4 and spent some time with the front end up today trying to find where oil was leaking at temps dropped below 25 degrees this week. The car is kept outside and the oil is collecting and dripping from the bottom of the compressor. Now, I notice there are two gaskets in the compressor, but it doesn't look like there is an oil system connection for it- could it be a part above the compressor? I looked around with an endoscope and couldn't see obvious leaks. Any tips on directions to go would be great. It stopped with the temperature went up and then leaked again when the temp dropped to 29. It was a tumultuous week.
Old Nov 18, 2019 | 09:13 PM
Is this engine oil you see dripping?
Old Nov 19, 2019 | 07:29 AM
Shanfara's Avatar
I don't know how I'd be able to tell between the A/C PAG oil and engine oil as I've never seen that type of oil before, but it looks like engine oil to me.
Old Nov 19, 2019 | 03:59 PM
pag oil if you have dye in it will be green engine oil is brown or black unless brand new them amber. PAG with no dye is clear.
Old Nov 19, 2019 | 06:00 PM
Shanfara's Avatar
Definitely engine oil, then, but I do not see oil anywhere but under the compressor gaskets.
Old Nov 19, 2019 | 09:55 PM
then possible oil pan gasket leaking it would not be the compressor itself
Old Nov 20, 2019 | 05:22 AM
Shanfara's Avatar
Ah, I will take another look. Thank you.
abacab
Dec 17, 2017 06:07 PM
mraskin
Oct 21, 2015 08:02 PM
mikec35
Sep 13, 2015 04:41 PM
jmobiles639
Jul 16, 2013 05:20 AM
garr5859
Aug 21, 2007 11:51 PM
