Oil light
Old 02-04-2011, 03:40 PM
antanel's Avatar
Default Oil light
I have a 2004 Pac and the oil light comes on when the has been warmed up for a while. When I'm driving it goes off but as soon as i stop and the car idle's it comes back on. There is plenty of oil in it so I'm not to sure what the problem could be. I changed the oil last night and it came on this morning. Please help!
Old 02-04-2011, 05:27 PM
Djinn-n-Tonic's Avatar
Engine size????
Typically, the oil sender units can get gummed up and restricted, which will not allow him to "READ" all of the available pressure.
Many of our motors are prone to SLUDGE Buildup, A weak oil pump, restricted pick up screen, bearing wear,or any other host of issues can cause a light to act that way.
Replace the sender and go from there.....
Old 02-05-2011, 03:30 PM
antanel's Avatar
The motor is a 3.5 V6. My wife took it to a jiffy lube before I got back from deployment and the light has been on ever since. What is the sending unit?
Old 02-05-2011, 05:33 PM
That would be the Oil Pressure sensor that is responsible for operating your warning Lamp.
Old 02-06-2011, 08:28 AM
antanel's Avatar
Thank you very much. I believe it's located right above the oil filter, right? I'll change that out asap and once again, thank you for your help.......
15951a\
11-24-2021 06:40 PM
qbasicer
09-25-2012 02:58 PM
vladio
04-05-2012 09:35 AM
milesy_boy
11
11-19-2009 05:34 PM
rollingrock
01-07-2009 12:50 PM
Quick Reply: Oil light
