Pacifica no crank, no start and electrical crazyness
Old Dec 15, 2016 | 08:46 PM
What year and engine size I never saw i in any of the posts
Old Dec 19, 2016 | 08:21 PM
Jake121's Avatar
2005 3.5 liter
Old Dec 20, 2016 | 09:54 PM
P0888-relay output always off tcm
p0499-nvld
canister
vent
valve
solenoid
circuit
high
Old Dec 21, 2016 | 01:03 PM
Jake121's Avatar
p0499-nvld
canister
vent
valve
solenoid
circuit
high
Ok so you are saying it could be one of ten things? Po499 is a code for that list and my relay output is always off?
Old May 27, 2021 | 01:00 AM
  #15
Becca4857's Avatar
Default Ground wire
Originally Posted by Jake121
Ok i still have not bought a new battery since I cant until later in the month. But now when I try to start it, the blinker lights turn on solid and the cd player turns on and off. Red light on the dash also. Rapid clicking while jumpers are hooked up and lights come on and flicker. Rapid clicking in the fuse box under the hood. Still have to disconnect the battery cable. I pulled the relay that says door nodule or something like that and the click would stop. Ive moved relays around that were the same number but still clicking blinking crazyness. I will try a new battery when I can, but ill be walking to work in negative temps until then so if there is anything else you think I could try, I would appreciate it. Thank you for any further advice
ground wire on back of tranny needs replaced
Old May 27, 2021 | 01:39 AM
  #16
Becca4857's Avatar
Default Ground wire on back of tranny needs replaced
This all started 3 weeks ago when my wife called me and said the car wouldnt start. Jumped it, got it home. Tried to start ot again and it had a rapid click. Took in the battery and alternator to autozone and both tested good. So I cleaned the battery terminals a little more(which were both pretty clean to begin with) and it started right up and ran good for 3 weeks. Now were back to the same story,(only worse) my wife calls me and the car wont start. I go jump it and it dies 3 times on the way back home(about every half mile). The lights dimming and randomly flickering the whole way home as it died. Got it home and it died in the driveway. I tried to start it and it clicked rapidly again. Rapid click coming from that relay box under the hood and the cd player and blinkers and pretty much everything randomly turns on and off...EVEN WITH THE KEY OUT OF IGNITION! the only way it stops is if I disconnect the battery... ive been letting my wife use my truck and ive been walking to work while scratching my head over whats wrong with her car. Please help me. I really want to figure this out without taking it to a mechanic. We just cant afford it. Please and thank you for anything
DKats
May 27, 2021 12:58 AM
Jake121
Feb 10, 2017 11:04 PM
Richardlss
May 9, 2011 10:49 PM
Sodak
Jun 17, 2010 02:06 AM
jds8535
Dec 21, 2009 04:39 PM
