persistent P0335 code: crank position sensor. Replace it?
Old Oct 20, 2018 | 07:50 PM
myf16's Avatar
Default persistent P0335 code: crank position sensor. Replace it?
My 2004 Pacific needs a new coolant cap. The old one doesn't hold pressure. I also have a P0335 error which comes back immediately when I reset it and start the car.
Is there any way that the lack of coolant pressure (and eventual boiling of coolant) caused the crank position sensor error? Or are these unrelated?
The car's other symptom is hunting at idle after about 5 minutes idling with the air conditioner turned on.
Should I buy a crank sensor and install it?
Old Oct 20, 2018 | 08:20 PM
myf16's Avatar
I forgot to add: The car appears to run normally. I always thought that a car could not run at all with a bad crank position sensor.
Old Oct 20, 2018 | 09:16 PM
Coolant pressure and its working are mechanical the crank cam and other sensors are electrical they are not related.
Old Oct 21, 2018 | 12:04 AM
myf16's Avatar
Thanks. I was wondering if overheating could cause a misfire and make the computer believe that the crank sensor was bad, but in that case the code would stay cleared after I reset it.
Unless the wires are melted I will bet that the sensor has gone bad.
Old Oct 28, 2018 | 06:01 PM
myf16's Avatar
I replaced the sensor. I had great difficulty separating the connector. Other than that it went well. The error code is gone.
eriemon
Dec 16, 2013 09:31 AM
paulesp
Feb 9, 2011 07:03 PM
01 blues
Aug 21, 2010 12:23 PM
mshgturner
Dec 12, 2009 06:44 PM
holdthewind
Cirrus & Breeze
Aug 25, 2009 05:42 PM
