Please help 🙏
Old Jan 10, 2024 | 10:28 PM
Biker4life's Avatar
Default Please help 🙏
I have a 2005 Chrysler Pacifica Touring all wheel drive with a 3.5 liter motor that I'm trying to remove a crankshaft sensor that someone else has broken off flush with the motor already. I'm at a complete loss of any idea of how to go about removing the sensor due to it being broken already and the position this particular sensor is in, that won't allow me to even visually see it let alone get any kind of a drill or anything to try to get a screw or any kind of tool in it to be able to pry it out? I've been searching the internet for forums, watched multiple videos on this type of issue and can't find anything for this particular year and make of vehicle or the unique position of sensor to be able to even make an honest attempt at removing this sensor? I'm a week in on this project and haven't gotten anything but a headache and high blood pressure into the entire mess?? I hope someone out there can give me some helpful advice!! I'm not an idiot and I refuse to give up on anything, but this one has me questioning everything?¿?¿
Old Jan 16, 2024 | 09:47 PM
Billy Pockets's Avatar
Default IV had a similar situation
I haven't had a crank case sensor issue but..
i Had to replace my water pump and with that had to replace the crank pulley, I had a friend help cause I didn't have a pulley puller, but my friend had one bit is was a small one and used a socket( yes a socket) right.. but that ended up getting lodged in the center hole cockeyed. So I had to get some drill bits and burr bits and took me a couple days just too drill that socket out..
What a job that was...
Old Jan 17, 2024 | 05:41 PM
get a drill bit drill a hole in the center then get something like a wall anchor that can fit inside the hole then it expands out when past it then you can pull on the item in the center. or use flat blade screw drivers and finish destroying the sensor and pull it out.
utahkat57
Jan 21, 2022 06:07 PM
James Scarlott
Sep 21, 2012 11:29 PM
rycb25
Dec 13, 2010 06:56 PM
96RedLXI
Jul 19, 2008 08:38 AM
funjon1
Jun 25, 2008 07:01 PM
