power loss 05 pacifica with 3.5
Old Feb 12, 2011 | 03:28 PM
chillnh3's Avatar
Unhappy power loss 05 pacifica with 3.5
I can not get above 10 mph. I have changed the EGR, Trottle position sensor, MAP sensor, an O2 sensor and I verified that 58 psi was at the engine using a fuel pressure test kit. I need help. The car seems to run worse after changing all these things. Now when I press the gas you can hear the engine bogg down and then it stalls. I still have a bank 1 sensor 1 and a bank 1 sensor 2, which is the one i changed, code. i am out of things to try.
Old Feb 12, 2011 | 08:45 PM
TNtech's Avatar
Clogged catalytic converter. Im guessing...uh...Bank one? Sounds textbook to me. Off to Meineke you go! Stop driving it before you melt something or even kill your engine. Things get HOT!
Old Feb 12, 2011 | 09:30 PM
Djinn-n-Tonic's Avatar
Alright TN.......If these guys would post in the proper spots , You wouldnt have "Jacked" my "SPOT"
Its all good
Originally Posted by Djinn-n-Tonic
58 psi at idle??????
2 things....Take the gauge, route it up under the hood and tuck it under the wipers, so you can see it from inside the car....(MAKE SURE YOUR CONNECTIONS ARE TIGHT< AND NO LEAKAGE) Now...drive the car, and make sure the pressure doest dump when you accelerate......
2)...Remove BOTH 'PRE-CAT" o2 sensors , and drive the car. If there is an improvement when you allow the exhaust a place to escape you will be expecting a plugged converter......Only long enough to evaluate your issue...Any exhaust leak is a potential fire hazard.
chillnh3
Feb 12, 2011 07:09 PM
tgpatton
Sep 22, 2010 08:19 PM
paul.siwek
Nov 24, 2007 03:02 AM
taffyd
Apr 24, 2007 06:42 PM
ChryslerNamedTrixie
Dec 22, 2005 03:55 AM
