Radio and Accessory power problem
Old Jul 25, 2014 | 10:10 PM
MikeE7's Avatar
Default Radio and Accessory power problem
2006 Pacifica, 3.5 - Has anyone had a problem with radio display not showing but the radio still works? No clock or station displaying, and the accessory plug ins aren't working either. We checked the fuses under the hood and all appear to be fine. Not sure where else to look or what to do.
Old Aug 19, 2014 | 04:22 PM
deepsea 1992's Avatar
Default Possible Solution
I have ran into the same problem. The power wire had broke and required a new wire to be installed. You can either replace the single wire or replace the whole harness. I believe that it is the Car Radio Accessory Switched 12v+ Wire: Pink/Orange. That is what worked for me. You can splice the wire into the harness before the fuse box or place a fuse inline and add a fuse. The wire that broke for me was between the fuse box and the harness plug, through the firewall.
Good luck.
Hollieking1
Jan 5, 2014 04:55 PM
donnyohs
Apr 28, 2009 04:19 PM
Iowacat
Aug 24, 2008 09:44 PM
jquinones
Feb 2, 2008 11:29 AM
eyruegas
Jun 20, 2007 07:43 PM
