Radio won't shut off
Old Jan 5, 2014 | 09:39 PM
cirrus98's Avatar
Exclamation Radio won't shut off
Well, 1st time ever this happen. Used my remote starter. I open my driver door after its done warming up(hence the car shut off) but the radio still played. Drove back home, turn it off, open the door and the radio is still going. Tried it again, it turned off for 1 second and started playing again(all this with my key nowhere near the ignition). Tried unplugging the battery. Doesn't work, has soon as its reconnected, the radio starts playing(keys in my pocket). I read about fuse#3 IOD. Took that out, wait 30 seconds, put back in and its still resumes playing(keys in my pocket). My only solution has been to reverse the IOD fuse. Now 2 questions come to mind:
#1, will it harm anything to drive it with the fuse reversed??
#2, if by reversing the fuse(then everything shut offs), would that mean that the fuse itself is faulty???
I'm good mechanically but when it comes to electrical, i'm stumped!!!
Old Feb 3, 2020 | 06:30 PM
Shelby Bennett's Avatar
Did you ever find a solution to the radio? I'm currently dealing with the same issue
Old Feb 5, 2020 | 10:18 AM
cirrus98's Avatar
Ends up when I went to the dealership, it stopped doing it. I guess a switch in the door was stuck(or frozen) on "closed door", hence why the radio kept playing. After spending an hour inside, never had the problem again.
jimedward
May 19, 2012 10:43 AM
jcmarle
Jan 18, 2011 07:37 PM
dwsmaintenance
Feb 28, 2010 09:52 PM
amapp0001
Nov 6, 2009 09:32 PM
goten903
May 29, 2008 10:45 AM
