Rear fans not working
Old Jun 2, 2013 | 03:29 PM
cirrus98's Avatar
Angry Rear fans not working
Hello fellow Chrysler buffs,
I've read numerous things about the front heater/ac fans not working. But I can't seem to find an answer on here for the rear fans. My front heating/ac works perfectly fine. All speeds, any temp. Before the rear ones stopped working, the middle one made a screeching sound like if the bearings were done. Now, does the actual blower have bearings?? What would make it stop working? Tried swaping fuses, get nothing. I can still "turn it on" but nothings turns. Even on manual settings when sitting in the middle. Please help.
Old Jun 28, 2013 | 12:18 PM
yup's Avatar
yup
There is also a relay in the fuse box you shoud check (swap with a different relay). You can check the continuity of the fan motor from the relay terminals when it is removed if the relay swap doesnt work.
Old Jul 11, 2013 | 08:59 PM
cirrus98's Avatar
Could you explain what you mean by CONTINUITY please. I swapped relays and nothing(rear fans) still works.
FX-IT-FLX
Feb 19, 2017 12:24 PM
Gromit
19
Aug 15, 2013 04:02 PM
red3737
Feb 19, 2011 09:24 PM
baldboab
Dec 12, 2010 02:37 PM
vlsgmc
Apr 4, 2008 09:26 PM
