Rear hatch Power liftgate Problem
Old Feb 27, 2011 | 08:24 PM
boise_chief's Avatar
Default Rear hatch Power liftgate Problem
04 Pacifica AWD
The power liftgate opens and then closes immediately. If it is open it will not close on it's own. I just joined and can't find anything on this using the search function. Any Ideas or help with the search I would appreciate it. It acts like it needs adjusted or that it might need a sensor replaced.
Thanks in advance.
Old Feb 28, 2011 | 05:34 PM
Djinn-n-Tonic's Avatar
It is QUITE COMMON for the "Strong arm Struts " to wear out.
The liftgate is meant to do this, in the event of an obstruction, it will reverse direction.
If the struts are worn, the added "DEAD WEIGHT" of the liftgate will be seen by the liftgate module as an obstruction, and reverse direction.
A WORD OF CAUTION...I have seen them wear to the point that the liftgate comes CRASHING down....So make sure your Skull is out of the way.....
Old Feb 28, 2011 | 08:16 PM
I should clarify a bit. The liftgate opens completely but instead of stopping it returns to closed. Also if it is open it doesn't close with the motor. It will beep twice open a little more and then stop moving.
str8hemi
Aug 25, 2017 08:39 AM
Nina1of5
Apr 9, 2011 05:05 PM
sdwhitney
9
Sep 22, 2009 06:10 AM
davet
Oct 26, 2007 11:27 PM
Fetta78
Apr 7, 2007 10:51 AM
