right front door PLEASE HELP
Old Oct 1, 2007 | 05:28 PM
bguerrios's Avatar
Default right front door PLEASE HELP
ok my alarm keeps going off after i set it. i sat in the car and waited to see what was going on and what i found out was that soon after my alarm was set the lights in the car came on and in the message window flashed right front door ajar. how is this possible when the door is shut and locked. i am sure that is some electrical mess. any suggestions?
Old Oct 1, 2007 | 06:16 PM
ace's Avatar
ace
Default RE: right front door PLEASE HELP
Its probably the door ajar switch. If the switch is bad its not sending the correct signal to say the door is shut. Its located either on the a pillar side of the doo frame or the b pillar. Its a small tear drop like switch that has a push in pin on the end. maybe about 7 to 20 bucks tops most likey the lower end
Old Oct 1, 2007 | 06:29 PM
bguerrios's Avatar
thanks for the info i looked for the switch you mention, if i am thinking about the correct switch i should be able to push it in with my finger right? because i cant find that type of switch in my door any ideas? could it be in the latch?
randibob256
Aug 5, 2011 12:33 PM
brownmal
Jan 9, 2011 05:28 PM
billyd10
Apr 3, 2010 02:54 AM
73SatWag
Dec 13, 2009 02:43 AM
97ysler
Feb 5, 2007 07:14 PM
