Shock/Strut Replacement
Old Mar 3, 2008 | 02:59 AM
edevries's Avatar
Default Shock/Strut Replacement
I've got 95k on my 04 AWD Pac. The ride has become soft and the car floats around more than it used to. Does anyone have a recommendation for front and rear shock/strut brand?
Also, does anyone have instructions for replacing them? Will I need an alignment when I'm done? Any special tools required?
Thanks!!
Old Mar 3, 2008 | 06:01 AM
Hi_Def's Avatar
Default RE: Shock/Strut Replacement
Edevries,
Here is what I found.
Monroe had Sensa-Trac and Reflex models. Sensa-Trac being the premium choice.
Front struts part # 72130 at AutoPartsGiant.com = $85.26 ea.
Bearing Plate part # 905911
Rear struts specialty part# 40211 = $329.46 ea.
I am having mine done today. I am only doing the front because the rear seems solid. The front floats a little and I like a tighter feel. I noticed the softness in the front when I go over speed bumps. I will let you know how it goes.
Old Mar 3, 2008 | 04:56 PM
edevries's Avatar
I'm very interested to know how your car performs with the replacement struts. I'd like to start with my fronts as well. Are you having the dealer or a local shop do it? Thanks!
Old Mar 14, 2008 | 10:24 PM
Hi_Def's Avatar
edevries,
I had the dealer replace my front struts and while they where at it I had them do the outer tie rod ends as well.
It rides much better now. Know more floating when on the highway. But I would still prefer a little firmer ride.
Had the struts, tie rod ends and four wheel alignment done for just over $700. for all parts and labor. They even drove me home and picked me back up.
Freedom Hudson
Jun 24, 2014 06:10 PM
chauffeurman
Nov 11, 2011 01:47 PM
jpcoolnuke
Dec 14, 2010 04:25 PM
blunk_blind
Apr 4, 2009 05:06 PM
cgytc
Jun 4, 2008 05:02 PM
