single pop
Old Jul 14, 2008 | 02:57 PM
gbeach's Avatar
Default single pop
any ideas on the loud mechanical pop when you turn the key after engine is warm
Old Jul 15, 2008 | 12:20 PM
Sierrasan's Avatar
Default RE: single pop
Is your AC on? Could be the clutch engaging.
Old Jul 15, 2008 | 01:22 PM
gbeach's Avatar
it usually is, wonder why it doesn't do it until engine is hot. I will check next time with it off when it gets hot. that could be what it is.
Old Jul 15, 2008 | 01:37 PM
gbeach's Avatar
maybe that's why you don't hear itwhen its coldbecause it takes a few seconds to kick
in. when it's warm maybe the clutch is kicking in before turning the car over.
Old Jul 22, 2008 | 09:29 AM
rmwjr's Avatar
I only hear it when I pause in the "on" position before turnign to "start". \
If you remove the plastic engine cover you see on the front of the engine a black metalic/plastic looking part on the front section that was under the plastic. This is the source of the sound. I pulled it apart and there is a plate on a hinge that flips about 45 degrees when the car is warm when the ignition is turned on. I'm GUESSING taht it redirects air in some way. I've decided that it is normal.
Old Aug 30, 2008 | 10:01 PM
gbeach's Avatar
wish i could figure out what this is. only does it when it is warm when you turn the key to on. does not matter if a/c is on. hearing it while driving also, very random. can not do anything to duplicate it.
Brewcity1
Nov 1, 2014 12:32 PM
loriac71
Apr 18, 2014 08:21 AM
missb2004
Dec 9, 2013 10:40 PM
Baby Jesus
Aug 23, 2012 08:00 AM
rmwjr
Jul 15, 2008 01:39 PM
