stalling 04 pacifica
Old Jun 14, 2016 | 08:33 PM
Marty Joseph Gaskin Jr.'s Avatar
Default stalling 04 pacifica
i have a 2004 chrysler pacifica. Ive changed plugs, cam sensor, crank sensor, map sensor, both O2 sensors, and the egr valve. Ive cleaned the throttle body and the idle air control valve. And ran fuel cleaner through it three times. Also tried sea foam. Just changed the air idle control valve. But my car still dies at a stop. I have to put in neutral and i can crank it back and drive.
Old Jun 15, 2016 | 11:44 PM
Barbara 2's Avatar
Could be as simple as a vacuum leak, can you shift to N just before stopping and keep it running ?
Old Jun 18, 2016 | 06:57 PM
Yes. Ive tried several diffrent things. I just replaced air idle control valve and throttle position sensor. Car still jerks some when taking off but not as bad. Ive rechecked what ive done so far and everything looks good.
Old Jun 19, 2016 | 09:27 AM
Barbara 2's Avatar
"Car still jerks some when taking off but not as bad" Was it doing this before it started stalling at stops ? If so it sounds like there are more than one problem going on. Strange but some have written about the alternator wave form causing various problems.
rambuck
Sep 25, 2021 12:50 PM
masteve69
Nov 20, 2020 05:26 AM
alphinr
Oct 31, 2016 10:04 PM
allstar
Jul 22, 2013 01:55 PM
timex4
Feb 26, 2009 07:56 PM
