Starter not crankin'????
Old May 16, 2009 | 12:34 PM
04_pacifica_4u's Avatar
Default Starter not crankin'????
I have had this problem here and there with my starting not cranking or even clicking. I think either there is a relay or my key is not being recognized. This is what happens, I get in my car and turn the key and everything works, such as the dash lights and everything else but when I turn the key to crank the engine nothing happens, not even a click. So I just keep turning the key and turning the key over and over again and eventually it will start but yesterday it did it again and I just kicked the plastic under the steering column and it worked right away. Is there a repay under the dash or somethat that has to do with the starter under there? Or has anyone else had this problem and fixed it?
Old May 16, 2009 | 07:10 PM
moe's Avatar
moe
you could have loose connection.there is no realy under that part .but there is your ign switch wiring.moe
Old May 17, 2009 | 09:51 AM
yeah seen the starter wire at the starter just fall off.
p8ntballnxj
Feb 5, 2012 07:23 PM
jtramont
Apr 21, 2011 07:59 PM
tsj44122
11
May 13, 2010 01:24 PM
Tracyw42
Oct 13, 2006 01:26 PM
MPMPM52
Aug 6, 2005 01:23 AM
