Two (2) Tied Rod failures on Pac
Old Nov 9, 2020 | 04:58 PM
djetelina's Avatar
Default Two (2) Tie Rod failures on Pac
This past spring one the aftermarket tie rods on my 2005 Pac unceremoniously broke, resulting in a wrecker trip back to my shop. Well yesterday the other (this time passenger side) tie rod broke. This time I learned that, if you drive carefully, you can steer a Pac with only one (1) tie rod.
Looks like a stress riser, inherent in the design, may be contributing to the failure. Pic attached.
Failed tie rods from 2005 Pacifica.
Detailed photo of failed 2005 Pacifica tie rods.
Old Nov 10, 2020 | 07:43 AM
Trucker Matt's Avatar
A very experienced mechanic who has done a lot of work on my semi truck over 18 years told me he won't ever use aftermarket parts-particularly drive train and axle components- because the odds are it is made with Chinese steel (not to be political here). He told me of job he did where he replaced all the U-joints on the drive line (5 total on a semi), and they began to develop play around 50,000 miles. Timken U-joints last upwards of a million miles or more if they are properly maintained. 1 bad u-joint could indicate a lack of quality control when forging the steel. 5 bad ones indicate poor steel quality.
djetelina
Dec 1, 2019 08:07 PM
Vikingtu
Apr 3, 2017 04:01 PM
BEAST2011
Jan 19, 2011 07:55 AM
theoldscout
May 6, 2010 01:07 PM
d50erock
Nov 21, 2006 04:10 AM
