Water in Light assembly
Old Jan 19, 2009 | 08:26 PM
awdtootall's Avatar
Default Water in Light assembly
I have water on the inside on my RH light assembly. No cracks, submersion, in fact I don't really drive that much lately. Not signs of water intrusion thru the back since I have after market HID lights but the rubber boot fits correctly. Not much rain while driving to maybe force water in from some point.
I removed it from the car, remove the bulbs, added some water to see if anything came out. Nothing. Added a bit of detergent to remove any dirt that may have crept in and now drying with a small fan to move air thru to dry it.
Any ideas?
Old Jan 20, 2009 | 08:21 AM
PacificaBus's Avatar
Default RE: Water in Light assembly
Could it be condensation that has formed this water? If the headlight housing isn't sealed properly the smallest hole can allow moisture in and create a puddle over time. The way you're talking it sounds like more water than this but I would check for any small holes and fill them with silicon. Good luck!
Old Jan 21, 2009 | 02:17 PM
awdtootall's Avatar
It was a puddle and so not just condensation. I poured out about a 1/4 cup. I did fill, not completely, with water to see if anything leaked where the lens is attached to the body. No drips. I have dried and re-installing it. Thankfully it's very easy to remove if it happens again. I don't want to fry my Pilot HID system due to moisture.
Old May 5, 2009 | 09:09 PM
dennisc's Avatar
How do you remove the light? I have the same problem, but can't remove the light completely. It's an 03, do I have to remove the bumper?
Old May 6, 2009 | 01:51 PM
If it's a Pacifica it's a 2004 or later. Once you remove the screws (2) you have to finagle it a bit to remove it.
Martyj160
May 14, 2012 03:35 PM
dmbeale
15
Nov 24, 2010 06:26 PM
captain catfish
Oct 2, 2010 04:32 PM
musicfreak2195
Jul 7, 2009 02:23 PM
Robinh
Jun 1, 2009 06:08 PM
