06 PT Cruiser Key Stuck
Old Feb 28, 2020 | 08:15 PM
JimmyJames's Avatar
Default 06 PT Cruiser Key Stuck
After replacing shifter and cable, the key is now stuck i the ignition.
Everything seems to work fine, other than the ignition won't go into lock and release the key.
The person who did the job took the steering column apart and said that the problem is a switch
inside and the whole column needs replaced. Its a floor shifter, when I put it in park and
press the **** I do hear a clicking in the steering column.
Any feedback would be greatly appreciated. Is there an easier way to get the key out or an easy
way to keep the battery from dying while still using the car without disconnecting and reconnecting each time?
Please help frustrated as can be Lbs!
JimmyJames
Feb 29, 2020 09:08 PM
JimmyJames
Feb 28, 2020 08:26 PM
tbird2340
Feb 19, 2020 04:41 AM
fyshbyte
May 9, 2018 10:34 PM
jent84
Sep 22, 2012 09:55 AM
