key stuck in ignition
Old May 9, 2018 | 07:07 AM
fyshbyte's Avatar
Default key stuck in ignition
2002 Sebring Limited convertible
Ignition key stuck in ignition
car will start just cannot remove the key
Old May 9, 2018 | 11:01 AM
There is an interlock system that includes a cable and electrical components that require that the transmission be in Park before the key can be removed. Disassembly and adjustment of this system is described in about a half-dozen pages of the shop manual and is too much to put in an answer here. Make sure the transmission is securely in Park before you try to remove the key. If it is securely in Park, then something is either broken or out of adjustment. The problem could be at the shift lever, under the console, at the ignition key or somewhere in between.
Old May 9, 2018 | 11:32 AM
fyshbyte's Avatar
Thank you for the info . do you know where can i obtain a shop manual online?
Old May 9, 2018 | 10:34 PM
I found one on eBay, but they come and go quickly. You have to keep watching. There are shop manuals on a Russian pirate site that's easily found if you don't mind that sort of thing.
tbird2340
Feb 19, 2020 04:41 AM
SEXYMOMOF4
Sep 11, 2016 06:30 PM
jent84
Sep 22, 2012 09:55 AM
woody79
Jun 11, 2010 09:59 AM
Justme1969
Jun 15, 2007 07:53 PM
