2003 pt cruiser engine light
Old Oct 6, 2011 | 03:14 AM
jackiepawprints's Avatar
Thumbs down 2003 pt cruiser engine light
I bought a 2003 PT Cruiser Turbo. One month later the engine light came on with codes 0456 and 0517. I took the car in on three separate occasions but I still have the problem. This is what the mechanic checked:
May19: tested purge solenoid - no leaks; tested all EVAP lines with smoke - no leaks; NVLD valve stuck open - constantly venting - will not close when commanded-replaced NVLD-EVAP test ran with MODIS and passed. Light still on.
June 8: Smoke tested and found a vacuum "T" for EVAP broken/cracked-repaired T and re-ran EVAP test with MODIS- passed. Light still on.
August 1: Smoke tested and thoroughly checked for leaks - none found; removed and cleaned EVAP lines of carbon; ran EVAP test with MODIS-passed. Replaced gas cap with new gas cap.
One week later the engine light went off on its own. After one month the engine light came back on.
The mechanic wants the car for two days for further pinpoint testing of EVAP system.
Does anyone have any idea what may be the solution or problem? Thank you.
Old Oct 6, 2011 | 08:28 AM
TNtech's Avatar
If it came back on after a MONTH, what makes you think it's still the EVAP system? Last I checked there were about 260 reasons it couild come on.
Old Oct 6, 2011 | 02:30 PM
I don't have a clue. The mechanic thinks it may be the EVAP system. Do you have a downloadable form that lists those 260 reasons? I am grasping at straws here. Thank you.
Old Oct 6, 2011 | 10:42 PM
TNtech's Avatar
Let me know what the codes are at this time. If it's still P0456 for small leak (we're talking .020") and he really can't find any external leaks, the most likely would be an internal leak inside the purge solenoid. If you're not well experienced in EVAP systems they will eat your lunch. As hard as my job is, I can't imagine being at an independent shop these days. What a cluster that must be.
Old Oct 7, 2011 | 02:30 AM
Thank you for getting back to me. The codes are still and always have been: codes 0456 and 0517.
I look forward to hearing from you.
Old Oct 7, 2011 | 09:20 AM
TNtech's Avatar
517 is a battery temp sensr high voltage. Not related to the EVAP code. Batt sensor is under the battery tray. May be unplugged. FYI, i've been burned on that 456 for purge internal leak a couple times. Engineer tests many times don't account for certain things.
Old Nov 2, 2011 | 06:47 AM
mikeaustin's Avatar
Thanks for the help.
JLAR
Aug 2, 2010 07:48 PM
Captmeach7
Nov 17, 2009 02:05 AM
Cynshine76
Dec 16, 2008 04:28 PM
pulpjava
Sep 15, 2008 07:20 AM
ernie
Jul 21, 2007 11:00 AM
